AFRAID: JDM, Built Motor, Detailed Bay, GT42, Hidden Wiring + several learning curves
I'm copy and pasting this from the Australian forum because I'm really, really lazy.
The plan;
Motor
Complete blueprint and balance
Knife edged crank
ARP main bolts
ARP rod bolts
Carrillo Rods
JE Pistons @ 20 thou over
ACL race series bearings and rings
Ported head
Custom 264 exhaust cam
Custom 272 intake cam
Brian Crower springs
Titanium retainers
5 angle valve grind
Brian Crower 1mm oversize intake and exhaust valves
Intake
JNT Performance bellmouth
GT4294
Sock filter
2.5" cooler piping
Some big fuck off front mount that came with the car
Port matched stock inlet manifold
Exhaust
Custom T6 turbo manifold (Treated and wrapped)
4" dump pipe
4" cat (Haven't sourced one yet)
Kakimoto 3.5" cat back
HKS internalled 50mm wastegate
Fuel
Titan motorsport hanger
3 x Walbro GSS-341 550hp pumps
Proflow fittings
1/2" hardline under the car
Braided line between pump hanger and undercarriage
Braided lines in bay
Modified stock fuel rail - twin feed with centre return (all -6 AN)
Aeromotive A1000-6 Fuel Pressure reg with guage
SARD 850CC injectors
Standard return lines
Electronics
12V fuel mod
3 x relay pack with fuses to run the fuel pumps
Haltech Platinum Sport 2000
HKS DLI
Basic stereo crap
Two piece loom with hidden wiring
Driveline
Fidanza lightened flywheel
RPS blue twin plate clutch
C's short shifter
Suspension
Whiteline front and rear sway bars
Some generic strut brace
Koni shocks
Whiteline springs
That's all I can remember right now. I'm doing the porting of the head myself - I'm not expecting it will be as fantastic as a professionals work, but I've done a couple of Commodore (Buick L27/L36/L67) cast iron heads in the past with decent enough results. I'm focussing mostly on getting some good shape into the exhaust ports to reduce heat soak, rather than the usual "make ports big and shiny" job. Inlets will be opened very slightly and finished in 120 grit. I'll get flow results regardless, which should show what an amateur can do with a 2J head :tongue:
The turbo I'm running has too big of a rear housing, but due to time constraints I won't have a chance to change it at this point - it's a 1.15 AR.
I'm just going to be happy to drive it again - it's been off the road since June/July last year.
Most of my pics are dodgy, so I'll get some new ones when I can.
The car;
I'll get a bunch more photos tonight.
Motor is currently down at the builders being balanced and the crank machined/knife edged etc. The head is at home on my bench getting the port work done. Fuel system is all prepared and waiting to go in, with the exception of the fuel rail which is still being modified with a return date of this coming Monday.
