Hey guys,
I have been having issues with my car and alot of smoke coming from the exhaust and I cant seem to figure out where its coming from. Also the car wont stay idling and will eventually die as well. So I ran a compression and leakdown test on it to see whats up. Keep in mine I am NA-T on a 2.0 mm Greddy Headgasket. First the compression results are as follows I believe I did do this test after the car had semi-warmed up:
#1-135
#2-153
#3-163
#4-156
#5-160
#6-152
Next I did a leakdown test. The leakdown test was on a Milton Leakdown tester and the car has NO OIL in it as I had drained it to check for coolant and instead found fuel in my oil. These are the results and again this is cold with no oil. The leaking air I could hear was all coming from the oil fill cap. These were also test a few times to ensure accurate results:
#1-11%
#2-24%
#3-14%
#4-18%
#5-14%
#6-18%
This motor has a little over 100k on it and has been NA all its life as far as I know I have owned it for about 4 years and it had 90k on it when I bought it. It has not seen boost yet. But im trying my hardest to introduce it to some.
#1-135
#2-153
#3-163
#4-156
#5-160
#6-152
#1-11%
#2-24%
#3-14%
#4-18%
#5-14%
#6-18%
