·I am currently installing the following parts:
Kenwood KVT-911DVD Head Unit
JL Audio 300/2 Component Speaker Amp
JL Audio 500/1 Sub Amp
JL Audio 12W6v2 Sub
Boston Proseries 6.5 Front Speakers
The setup will be just a clean, stock looking setup. No fancy fiberglass and bright colors. I mounted both amps on the rear seat next to each other, and it fitted perfect. The front component set are mounted on the door panel with the new grill, and their crossovers are hidden in the stock sub location along with the power fuses, etc. As for the sub box, I am building a regular MDF box, so it can be easily removed when needed. Feedback is appreciated.
Also, I'm installing a alarm, Clifford Intelliguard 8000 and Intellistart w/ a bunch of other accesories.. Where should i mount the brain? Zip tie it under the dash like most installs?
Thanks!
JL Audio 12W6v2 Sub
Thanks!
