Long story, but here is the shortened version:
I went to the track last night to test out the new clutch and ET Street Radials...mainly I needed to know what tire pressure I wanted to be at, but unfortunately it was sprinkling on and off all the time I was there. That is definately not a good comparison when before I didn't run in the rain.
They were still running cars every time it stopped, but I just decided to go home after it started sprinkling much harder...it was all kind of a waste of time anyway IMHO.
The only thing I got accomplished is trying out the new clutch and getting used to it. The clutch is very consistent as far as slipping goes...you can definatley slip it very easy and this setup doesn't bog or anything like that if you do happen to let it out early. The only downfall to letting it out early is you might spin.
Since it was sprinkling on and off and then started coming down harder I went home and unfortunately I didn't get the tires down to where I think they might do the best...I only got them down to 15psi and the car didn't hook all that great. It only managed a 1.78 60', but not sure if that is the rain on the track, or the fact that I don't know how to drive with this clutch yet.
I guess the bottom line is that I have to go on a much better day next time...last night was a horrible day to go. They also just re-surfaced the first 330' of the track, so the rubber isn't the same on the track as it was when I ran before. I am not sure how much that really played a role in my traction issue though.
I will either get these tires to hook, or just go back with the normal ET Streets. I can say though these tires hook just as good as the normal ET Streets on the street though. The G-meter on the track was around 1.24-1.25G's with my lower tire pressure and the meter on the street showed around 1.20G's shortly after the track...it wasn't raining at all 10 minutes away. Very weird night last night with the rain.
If I end up putting normal ET Streets back on the car I will measure the G's again on the street. I know for a fact when it hooks at the track it pulls more than 1.25g's, so it won't do anygood to measure that on the track since my Pioneer AVIC-N1 only goes up to 1.25G's.
I will keep everyone informed of the progress with the clutch/tires combo.
Take Care
