1 - 20 of 106 Posts
Supra Enthusiast
After running a 13.8 at TX2K6, I realized that I needed lots of track time. I started that night with a 14.6, then a 14.somethin, then a 14.01 and finished with a 13.8.
Last night, IdealSupra, F & H Performance, Dr. Bowser and I went to a local Test N Tune. My first pass was a [email protected] I leaned the car out a tad in the mid range then ran a 13.9 again but this time at 104. My 60ft times for both were 2.2ish so I was definitelly fighting to get out the hole. My third pass was a [email protected] which lifted my spirits for sure to be back on track. After dropping the tire pressure down a tad more and launching a little higher, I was able to pull off a [email protected] with a 60 ft of 2.0. Needless to say I was friggin happy that I was able to drop my time down a bit and bring up my MPH. Now I just need to get my 60' times down and find out the best place to launch.
**Readers Digest Version**
Ran 13.8 @ 100 at TX2K6
Last night at local Test N Tune
1st pass - 13.9 @ 100.51 60' - 2.2
2nd pass - 13.9 @ 104.84 60' - 2.3
3rd pass - 13.6 @ 104.69 60' - 2.2
4th pass - 13.4 @ 104.43 60' - 2.0
Now it's time to change/fix a few things and head back. The 13.8 at Texas was the first time that I had ever ran a 13, and that was an amazing feeling. Now, I can almost taste a 12 second pass. I know that it's there, I just have to find out how to get it :faint:
-Eli
BMM
very nice! 12 is deffinetely in your sight bro, keep it up!
Good job man!! what turbo setup do u have? anyways good numbers :bigthumb:
saif
Supra Enthusiast
Basically I have a SC61, 550's, 3" turbo back, hardpipes, ic, 3923's, vpc, gcc, tial wg with .9 spring, eibach springs, and tokico blues. I'm also running MKIV wheels with Nitto 555's
Good passes. whats your mods?
RIP 86.5 N/A, Hello 90T
Kick ass Eli, glad to see you getting some track time.
As for me I ran an 11.5 last friday
on my bike :)
~Dan
damn with that setup you can definitely do a lot better. a decent driver can get a BPU ct26 mkiii in the 13's, just turn up the boost!
How much boost are you running? nice to see that you have the times down but with that mph I would guess your hp is right around 300rwhp. (or have you dynoed or tunned yet?)
Supra Enthusiast
Discussion Starter #9
I'm running off the wastegate which is the .9bar spring. As far as dyno time or actual tuning, no. As soon as I install my new fuel management, I'll tune and get some dyno time.
Supra Enthusiast
Discussion Starter #10
Speaking of turning up the boost..........
When I ran that 13.8 @100 in Texas, I had a manual boost controller and was running about 17-18psi. The 13.4 @ 104 was just off that wastegate. Once I get a boost controller I'll turn her up and see what I can do :naughty:
what do you all think about a 13.7 @106 with a 2.47 60'? lots of wheelspin till 3rd gear.
Project:: Reaper
not too bad i guess. I have the stock CT26 set at 16 psi, full 3in turbo back, 550's, lex afm, apexi intake, and no tuning and went 13.4 @104 with a 2.034 60' on IS300 wheels with shit 235 bridgestone tires. you can do better man c'mon!!!!!
Not so boring anymore
yea.. your deff down on power.. Get a wideband and tune it! check for boost leaks..
pretty good driving.. power shit and bang the gears to hell.. how i managed to get a 13.52 at 102 with only a 2.06 60'.. lol
RTA Supra said:
Sounds like F & H's run last night. Hopefully he'll come on here and share = P
I thought they trapped 116mph? 10mph in the 1/4 is a HUGE difference. 116 is good for a low 12s pass with a good driver.
You guys are lucky I didn't come out and join! ;) On my slippy clutch runs I still would have killed you both.
Supra Enthusiast
Discussion Starter #17
:jerkit: :blah:
Don't make me piitb again. All I hear from you is talking. ALWAYS trying to one up whoever it is you're in the conversation with. Just bring it. That is all :takethat:
Not ur jizz, not ur bizz
RTA Supra said:
:jerkit: :blah:
u know eli, u had ur chance to PIITB to kelly @ texas when u were sleeping naked under the sheets in the same bed kelly was in!!!
but you fell asleep u tank volume snoring bastard!
btw, good runs...time to get into the 12's i know u can do it..get better tires.
1.5JZ Turbo Supra
RTA Supra said:
:jerkit: :blah:
HAH! reminds me of that commercial
1 - 20 of 106 Posts
