Thank you very much.Looks like a typical japanese supra!Congrats with the car!
Taking all those things into considerationCongratulations on the purchase. I would say ditch the rims, CF vinyl panel wrapping, and the e brake handle needs addressing.
Not a big fan of body kits, but the car looks nice and straight! Definitely a good starting point TT and assuming the w58 was replaced with a 6 spd.![]()
Thank you ill have em take pics with the wheels off, maybe you guys with more experience may be able to identify them on sightThe front look like Brembo, but not sure on the rears.
The photos are taken with the wheels obscuring the calipers too, which isnt helping to identify them easily.
What ECU is running your TT swap? Looks clean.
Sent from my SM-G950U1 using Tapatalk
That's a piggyback I think. Still running NA computer too?![]()
Everything is HKS
Doubt it- I would be surprised if it did.That's a piggyback I think. Still running NA computer too?
So likely running a gte ECU with that piggy back for fuel.Doubt it- I would be surprised if it did.
It already has a GTE swap.
But then again, I dunno shit. I'm still learning. LoL
Sent from my SM-N960U using Tapatalk
Thanks, as for now it seems to have a 5spd transmission.Nice Supra! Looks like you're making good progress on updating the exterior and interior parts!
There's no way to run a GTE ignition system with a GE's ECU so the ECU was swapped at the same time for sure. The engine is from a Supra RZ as well so it likely just got the whole wiring harness and everything else from the RZ donor car. The Fcon IS is an effective but simple piggyback that works great for basic 'boost up' mods and such on stock or near-stock sized injectors. I wouldn't bother messing with it for now so long as the car runs well and makes good power.
The front calipers look like Brembo F40's but the interesting thing is the rotor. The Brembo GT Big brake kits all use a 2-pc rotor, and those rotors appear to be 1-pc, so I'm curious as to the nature of the kit itself. Judging by the intake piping on the engine, the car saw the attention of someone with some fabrication talent, so I wouldn't be surprised if the brackets are one-off custom jobs to suit whatever rotors those are and the Brembo brakes came from a totally different source.
Does the car have a 5spd or 6spd transmission? Nice score either way! But if you've got a 5spd, try to get some pictures of the underside so we can tell you if it's the original NA W58 box or a stronger R154.
