1 - 19 of 19 Posts
What is ducted to what off the main bumper + that lip?
Looks like you got a good setup there. Does it help the Supras' cooling problems on the track?
Looks pretty wicked and like you have done a lot of work on it. What kind of cage do you have in the car? Looking at the back wing makes me want to put a nice big splitter lip up front to maybe get some downforce/grip up front too. How much does the car weigh now? Nice car!!
Barry H.
Very nice and damn serious looking track car. That front looks like it scoops up so much air, I hope there's some left for the rest of us!
Discussion Starter · #11 ·
badkarma said:
That's a good idea with the lip. I never even thought of that! I use the side holes for brake ducts but didn't even think about cutting the middle out. Are you ducting the middle to your rad?
yes the the lower duct in the middle diverts air up into the radiator and a second oil cooler.
Discussion Starter · #12 ·
The duct between the headlight covers goes to the radiator and the oil cooler
the lower middle duct goes to the same place. The small side ducts go to the brakes and the passenger side under light duct goes straight to the turbo.
Discussion Starter · #13 ·
Barry H.
Part of the cage is the auto power roll bar and the rest is custom weleded and bent D.O.M. The cars weighs just under 3100 and a splitter is in the works.
· Oh Snaps
Where can the air duct to the radiator be bought? or was it custom? And about how much did it run you? Also if the hood custom matched to the air inlet so it flows well, or is that someone's hood?
-Mark
Discussion Starter · #16 ·
-Mark
Both pieces are custom, matched and flow well, this mod lowered my water temps and oil temps at the track. You can contact Afterhours at 714-220-2030 for price and info on the mods.
What Size oil Coolers?
Hi,
I was wondering what size oil coolers you have, and where do you have them located exactly? Also, what size lines do you have to and from the oil coolers? Thanks for the info and beautiful Car!!
Russ
Discussion Starter · #19 ·
SupraLaal said:
Hi,
Russ
I have a setrab aprox 8x12 in the duct below drivers side light and I am running a fluidyne zr1 cooler in between my intercooler and radiator. The zr1 cooler is very high flow measures 27x12x1 and can run an12 lines but I believe my whole system is running an 10 lines.
1 - 19 of 19 Posts
