1 - 10 of 10 Posts
I've been trying to figure out all the parts needed to make the oil/send return lines and I came across Jaxin's page: http://www.funkyard.i8.com/Supra/TechArticles/Main.html which has (I believe) all the components listed. I went ahead and matched the part number/prices from http://www.anplumbing.com. I was wondering if someone could double check the list for me and see if I have all the right parts?
Oil Supply Setup:
1 x Lexus IS 300 Union Bolt (PN #90401-19008) + Gasket (PN #90430-20016) $??
2 x Straight (-4) AN Swivel to Male (1/8) NPT Adapter (Part Number #916104) $6.62 x 2
(-4) AN Perform-O-Flex Premium Racing Hose (3 feet?) (Part Number #00040) $6.00(per feet) x 3
Oil Return Setup:
2 x Straight (-10) AN Swivel to Male (1/2) NPT Adapter (PN #916110) $11.32 x 2
1 x Swivel-Seal 45 deg. LP Hose End (-10 AN) (PN #804510) $25.46
(-10) AN Perform-O-Flex Premium Racing Hose (2 feet?) (PN #400100) $9.18(per feet) x 2
1 x -10AN Swivel-Seal Straight Hose End (PN #800110) $10.97
1 x (1/2) NPT Female Weld Fitting (PN #996704 $5.11
1 x stock TT oil line return gasket (PN #15472 - 46010) $2.55
1 x ~4in x ~4in piece of metal (used to make custom flange) $??
Couple more questions... Am I missing any parts? Does the length for the hoses sound about right? (I'm going to be running daveh's setup with a pt51 turbo) and does it matter how thick the ~4in x ~4in piece of metal is? any kind of metal would do?
Thanks....
The Union Bolt was like 20 bux from lexus of new orleans... Personally I would just go ahead and spend the 20 bux rather than drill a hole on the stock bolt..
Flipn
Yeah, I'd much rather just buy the union bolt.. would be much easier I imagine... anyways... come on guys.. I know somebody must've made the oil send/return line themselves... please check thru the list and see if I got everything right? thanks in advance......
would just like to check if this lists all the components needed. thanks!
ah, how much does it cost for just the lines? thanks
LexusTico
:scratch: same thing...
go to any machine shop... the guy in the back would probably do it for free... takes about 60 seconds... then go get yourself a case of beer or 2
Formerly NA-TT
Tico, why did you bring this back????????/
1 - 10 of 10 Posts
