I'm putting together a turbo setup for my N/A (i finally decided to go N/A-T rather than doing a 2JZ-GTE swap) and i've been looking at everyones setup. . .what do you do with the second o2 sensor? From what i can tell on the N/A-T setups that i've seen, everyone has one sensor that's mounted on the downpipe just after the turbo. (and I assume that the 3rd o2 sensor [the one behind the cat] should just be replaced with an o2 sensor simulator.)
Thanks!
This is what I did, which Im realizing now might be wrong:
Sensor 1 --- Sensor 2 (cut)
power1 spliced to power
ground1 spliced to ground
heater1 spliced to heater
oxygen1 spliced to oxygen
should I do the following:
unsplice: power, ground, and heater and just splice in Ox1 and Ox2?
