i have the boost logic 2.5 mm HG running E85 boosting at 22psi pretty safe i believe.
anyone go higher then this? ill like to boost 25-26. possible?
i have boostlogic 2.5mm i have been tuned to 23psi on pump , did not go race gas tune but having FULL control of timing and fuel is crtiical in a na-t setupi have the boost logic 2.5 mm HG running E85 boosting at 22psi pretty safe i believe.
im on the aem ems alsoi have boostlogic 2.5mm i have been tuned to 23psi on pump , did not go race gas tune but having FULL control of timing and fuel is crtiical in a na-t setup
i am aem tuned and have zero issues
Def and easily doable. Just make sure you have at least 1kcc injectors since e85 requires 30% more fuel then 93OCT.im on the aem ems also
im shooting for 26psi on E85 this weekend. goal is 700whp.
race gas?My car's on 30 psi using BL 2.5mm HG & aem ems.
I admire your setup man. Got pics? More specs on the car? This is EXACTLY what my setup will be like when Im ready to build one of my Supras.i run a stock tt head gasket with arp head studs. with c16, cams, bl kit, and a 71, i made 722 with bad breakup. i also conservativly make 650s on e85 every day.
yes q16race gas?
Dave H fuel railI admire your setup man. Got pics? More specs on the car? This is EXACTLY what my setup will be like when Im ready to build one of my Supras.
OP- Dude thats easily achievable. You got the compression and fuel, turn the boost up. Whats your fuel setup looking like?
http://www.e85refueling.com/Where can I find E85 in SO. Cal.?
yep lj will be tuning it. well see what happens! might drop it off at the dyno today if i can find some time.good luck on hitting the numbers Triet, you shouldn't have any problems. Is LJ tuning it? My car is going back for the corn.
