1 - 14 of 14 Posts
Hehe... sorry to hi-jack your thread, but I love 2jz-ge motors. I just picked a longblock with 70k miles for... get this - $350. :)
You'll need to do an inventory of all the parts from your purchase. Only then, can we provide help. For example, the picture shows a transmission, but the auction says "engine, harness, and ECU", only.
-scott
^^^^True Statement.
USMCSupra said:
More than 1k for some... :sadance:
Ive spend around $1500-2000 on nickle and dime stuff. And I'd believe i got mostly good deals. Now all I need is regular maintenance stuff. And a downpipe.
Can you tell me like what do you have to spend , sorry .
Thank you for your help.
From an OBDII 98 NA > OBDII 6spd TT US Spec
In no particular order and a lot of small items missing:
JDM Aristo 2JZGTE motor
Transmission
Driveshaft
rear end
axles
Engine Drive Belt Tensioner Assy
Clutch
Clutch Hydraulics
Shifter Assy
Console
Brake
Clutch Pedal
rear cross member
Intercooler
Fuel Pump
OBDII ECU Harness
OBDII 6sp ECU
6spd Tach
Stock Fuel Rail and Injectors
MAF
Oil Pan
Coil Packs
RESISTOR
PUMP WATER
BELT
PULLEY
IGNITER
TRD trans mount
TRD engine mounts
Passenger Engine Mount Bracket
Fuel Pump Hanger Assy
Fuel Lines
TT TPS
Downpipe
Exhaust
OBDII Fooler
Probably more all I could think of for now...
obd 2 fooler?
im almost done with my swap... whats the obd 2 fooler? also i had a quick q? if you use the n/a auto tranny do u have to extend the kickdown cable?
Transmission
Driveshaft
rear end
axles
Clutch
Clutch Hydraulics
Shifter Assy
Console
Brake
Clutch Pedal
rear cross member
Intercooler
Fuel Pump
OBDII ECU Harness
OBDII 6sp ECU
6spd Tach
MAF
Oil Pan
Coil Packs
RESISTOR
PUMP WATER
BELT
PULLEY
IGNITER
TRD trans mount
TRD engine mounts
Fuel Lines
TT TPS
Downpipe
Exhaust
OBDII Fooler
OBDII to remove the check engine light when you remove the rear O2 sensors. I had a 98 na auto, no kickdown cable.
-Joe
I HIGHLY recommend not using the NA auto transmission.
I blew up 2 while na.
A TT auto is much stronger and only goes for a little more.
1 - 14 of 14 Posts
