1 - 9 of 9 Posts
Just figured id ask you guys about my a/f readings. I have a wideband o2. TE44 stock HG, inj, fp.
At cruising speeds no boost im seeing 14.7-15.8a/f on the digital display...
at WOT 7psi(wastegate pres.) im seeing 10.6-11.3 a/f.
Are these within spec?
i took it out on the road and did some what of a road tune. only really adjust though the throttle cross over point to 74/75 and the lo/hi settings.
King of the NA-T's
It looks like you have it tuned quite nicely. It's a pretty conservative tune, at only 7 psi I'd lean it up under boost to around 11.8:1 a/f.
are we not supposed to adjust the lo throttle settings? Or is it okay?
King of the NA-T's
I would not adjust the low throttle settings. The ECU will try to counteract the changes you make to the low maps.
when i didn't have the lo throttle adjust it seemed to me that it was quite lean. 15.8-16.
1 - 9 of 9 Posts
