R
Rob_O
·Guest
Here's one that you would probably have some thoughts on, Dave, seeing as you own one of each of these cars
Since the MK3 turbo guys use the Lexus AFM as a way to trick the ECU into being happy with 550's, would it be possible to use the same idea and use the Lexus AFM to allow the MK4 NA to use the 440cc MK3 Turbo injectors? Obviously the resistor would have to be added for the low impedance injectors but the difference in calibration should be about the same
Thoughts... Anyone?
Rob_O
Thoughts... Anyone?
Rob_O
