whats the difference b/t the MC's anyways?Yes, and no. They bolt right up without a problem, you just need the calipers, pads, and rotors. Other than that, its a complete, easy install. You also DON'T need the TT MC. I just did the swap on my sc300 about a month ago with no issues then or now.
Not sure what you mean by "bracket" because the TT brakes don't necessarily have any brackets on them. You need calipers, pads and pad accessories, (shims, guy pins, etc) and rotors. Thats all I have, and I haven't had a single issue.so we dont need the TT brake brackets? just strictly the pads rotors and calipers?
Probably not as much of a noticable improvement if any. Most of the braking will be done by the fronts anyway since that is where all the momentum isAnyone changed out the rear's to TT? If so was it a great improvement?
I think the only difference is that the TTs had to accomodate for the TRAC system.whats the difference b/t the MC's anyways?
You got fucked if you paid 2200$ (no offense of course). There is no reason to purchase new braking equipment - simply inspect the pistons and seals of the used calipers and ensure they are within spec.I just swapped front and rear at Toyota. No change in MC - no mention from them that it was needed. Parts ran $2200 frt&rr. Backing plate/dust shield used on fronts. Not used on rear because of parking brake which would need a new press bearing to get the backing plate off and new one on, about $1000 moreTech trimmed the lip of rear backing plate to allow larger rotor and worked great. Can't even see it. The only problem I might see about using front w/o rear is IF your brake bias was thrown off. Don't know the answer to this. I can tell you the brakes make a huge difference. I know the car isn't that fast but stopping quickly at any speed faster is nice. My wife noticed right away and she didn't know at the time they were upgraded plus could care less about cars stuff anyway.
LS400 fronts are a 4 piston monoblock aluminum design that was developed to stop a 2 ton vehicle. They're 8lbs lighter per caliper than the Supra brakes, but have a .5" reduction of total rotor size. However, the calculations came up that the difference was negligable. For the cost... ~150 for calipers (loaded) and 70$ for OEM rotors, it cannot be beat. I did the writeup on it several years ago, I think dejacky re-did the writeup a few months ago.Hey MadMaxx, I didn't have any used brakes to inspect - that's why I ordered them new. I would have gladly bought the used ones you had if I had known. What are you asking for them? What is the difference in the LS 400 brakes - are they also 4 piston fronts and 2 piston rears?
I was planning on going the TT swap route - but I have started researching alternatives to see what might be most cost effective. Any feedback is appreciated. Nice to find someone locally with knowledge and a supra period. Drop me a line and let me know what you've got. Maybe we can get together some time and check the cars out. Thanks for the reply.LS400 fronts are a 4 piston monoblock aluminum design that was developed to stop a 2 ton vehicle. They're 8lbs lighter per caliper than the Supra brakes, but have a .5" reduction of total rotor size. However, the calculations came up that the difference was negligable. For the cost... ~150 for calipers (loaded) and 70$ for OEM rotors, it cannot be beat. I did the writeup on it several years ago, I think dejacky re-did the writeup a few months ago.
In the future, please feel free to PM me if you have any questions. I'm in G'ville, I may already have the parts you need and have been taking these damn cars apart for years now :lol: Are you going NA-T or TT in the future? Got some goodies for ya...
