Robbman said:
I read that, even posted in the thread. To recap (and to repeat what I posted in that thread)
The normal state of the butterfly valve is open, not closed. if it was closed, the cold start injector woud only feed cylinders 1-3.
When vaccuum is applied, the valve closes. The valve activates at 4200 RPM, thus it closes at 4200 RPM, creating the long runners, not short (same time as the fuel pressure up VSV activates, which is interesteing, becuase on later 7M-GEs, the FPU and butterfly are controlled by the SAME VSV, which means there is not multiple open/close operations of the valve as on a true ACIS system))
This is completely at odds with what you wrote about the ACIS system on the 1MZ and 2JZ (and I'll note, you have nothing on that page that shows the 7M-GE system, just the 1MZ and 2JZ)
Replacing the Y-pipe with throttle bodies would not ruin the long runner/short runner effect either. The throttle bodies simply become part of the 'long runner'. When the butterfly valve is open, you still have a short runner...
alrighty... well then toyota must be misinformed about their ACIS system, because i took all of that information directly off our TIS computer database. There was no information directly relating to the ACIS on 7m-ge, BUT... There was a wealth of information regarding the ACIS system on the 2JZ-GE/FE and in there, toyota said, " This ACIS system is identical to the system found on the 7m-ge." if you want me to download all the .pdf 's so you can read them yourself, then i will.
I'd like to know how exactly replacing the Y-pipe with throttle bodies wouldn't change the acis effect? The long runners utilize the Y-pipe... if you remove the Y-pipe, then there is no longer any long runners.. its just short. the butterfly would open and close with almost no difference, I'm sure the Toyota engineers had something in mind when they designed the system with Y-pipe, and --although purely speculation-- would agree with me, that removing that Y-pipe, although more than likely benificial in terms of throttle response, would completely change the geometry of the intake manifold, especially during the "long runner" operation, and thus change the ACIS effect. That manifold, INCLUDING the y-pipe, was designed acousticly... Its about the pressure waves, sound. I"m sure you've blown across a bottle once in your life and noticed that different lengths of bottles resonate at different frequencies, or the same can be true about an open end tube over a speaker ( like a bandpass sub box) the tube, depending on length, will create a resonance at a certain frequency and its octaves. That same principle holds true for the ACIS system.... for example...
Lets say you have a speaker producing 120Hz ( speaker = valve in our case) and, a ( wild guess) 2 foot cardboard tube with an I.D of 2". That 2 foot tube will resonate at 120Hz... but... we want to cut that tube down ( remove y-pipe and replace with throttle bodies) lets say we chop that tube down to 1 1/4 foot. That tube will no longer resonate at 120hz. Thus, the "supercharging" effect is lost ( at 120Hz).
If you were to shave 1/8" off that Y-pipe, you would change the ACIS system. any change to that manifold, Y-pipe, throttle, or butterfly valve could easily and probably dramatically change how ( more specifically when) the ACIS system operates. my guess, Toyota optimized the system to give the engine best performance, i doubt there is little room for improvement, and i'm willing to bet you would lose any ACIS gains by altering it.
furthermore, by calling the ACIS system on the 7m-ge anything but a "true" acis system soley on the grounds as it doesn't have "stages" in terms of different throttle % activation, is pure horse manure! Its ACIS, Acoustic Control Induction System, it does EXACTLY what the system is supposed to do, and it does the SAME DAMN thing it does on every other toyota engine, it changes the length of the intake runners to optimize the air flow in terms of acoustic pulses. Ok, so toyota made some improvements on the system over the years, which is understandable, by giving it more features and control by adding more butterfly valves, VSV's, activation RPMS, and throttle % activations. But its all the same! ACIS is ACIS... There is a simple ACIS system, or a complex ACIS system, both are TRUE ACIS!!!! what your saying is like... " A 1990 supra isn't a true supra because it doesn't have a 2JZ..." A supra is a supra, toyota made revisions and changes, are you saying then that a 1990 supra isn't a true supra? COME ON!?
You're comparing apples to apples and calling one an orange!
