Robbman said:
1. Show me a proven reference that Toyota calls the 7M-GE system an ACIS system. There is almost a decade between motor designs between a 7M-GE and a 2JZ-GE. The 7M system operates exactly opposite to what you wrote about the ACIS system. Either Toyota is wrong, or you are. They are different... period. If you call the 2JZ system an ACIS system you can't call the 7M system an ACIS system. Maybe there's a reason why there was no mention of 'ACIS' until after the 2JZ and 1MZ were introduced (93 and 94 respectively...)
A carburetor and TBI both do the same thing, provide fuel for a motor, but you don't call one the other on that basis do you?
2. Using two throttle bodies, the runners are still separated. The length of the Y-pipe now becomes the length of the throttle bodies. I see where you're getting confues though... I'm saying to attach the throttle bodies directly to the upper manifold.
3. Speaking of comparing apples to an orange...
If there were little room for improvement, and Toyota acoustically designed the 7M-GE, then there would have been no need to change the design so drastically as they did on the 2JZ-GE. Larger diameter runners, larger diameter Y-pipe, different upper manifold design, etc all affect the acoustics of the manifold.
1. I'm going to work tommorrow. I'll do just that. And if you want to get technical, the M series motor was around 30 years before Toyota even knew what a JZ series motor was. I'm calling both systems ACIS systems, because they vary the length of the intake runners, which is what ACIS is all about. I would call a TBI and carb "means of providing fuel to an engine" becuase that its what they do.
Please tell me how the system on the 7m-ge DOES NOT change the length of the intake runners.. i would love to hear you explain.
And, of coarse, I must be the incorrect one, or possibly even toyota, for labeling a system that is doing exactly what its name describes.......
2. No.. i'm not confused at all about what you are saying. Lets simplify things and look at it from a single dimension; length. Lets measure the distance from the intake valve seat to the point where each runner gets the same amount of air ( shared air). Ok... now, using guesstimated numbers, we can see a difference here. With the ACIS valve closed... The shared air is just behind the TB, lets say it has a distance of 28 inches before reaching the valves. When the ACIS valve is open, the shared air is in the middle of the intake manifold. Lets say that has a distance of 19 inches before reaching the valves... The difference is 9 inches.
Remove that Y-pipe, and there is no longer "SHARED AIR" in the ACIS valve closed stage... Thus making it POINTLESS... The length difference then becomes about 2 inches, and you wouldn't gain anything except throttle response.
3.
You are comparing Apples to oranges... The M series and JZ series are completely different engines! Aside from obvious things... Thats like saying toyota improved the 5s-fe with the 3s-gte... come on! thats just dumb. toyota did improve the M series engine over 30 years, but calling the JZ an improvement of the M engine is pointless becuase its a different engine series. Of COARSE, they are going to change the ACIS system "drastically" on a DIFFERENT ENGINE... I'm
sure the Toyota engineers said " oh ok, well, lets take the exact ACIS system from the 7m and throw it on the 2JZ, even though the compression ratios, valves, and pretty much entire air flow through the head is different!"
hey, heres a good idea, lets take the ACIS off the 3s-ge and throw it on a 2UZ!! that makes sense.
of coarse they are going to change the system, its a DIFFERENT ENGINE!!! Derrrrrr :stickpoke:
A little history for ya...
In the 1980s toyota developed a system they called T-VIS. Toyota - Variable Air Induction Systems. They put this system on the 3S-GE, 3S GTE, and 4A-GE engines. It effectively changed the volumetric efficiency of the engine and Intake manifold. This system utilized long thin runners at low engine speed to keep intake air velocity up, and wide runners at high speed to help the engine breath.
In 1986, with the introduction of the 7m-ge, toyota introduced ACIS.
"The Acoustic Control Induction System (ACIS) is used on the 7M-GE, 3VZ-FE and 2JZ-GE engines. As with the T-VIS system, the purpose of this system is to improve engine torque throughout the engine rpm range. The system consists of the same basic components as T-VIS and operates similarly. The ACIS system uses a single intake air control valve located in the intake air chamber which effectively changes intake runner length as it opens and closes."
oh.. btw.. the ACIS on the 7m-ge is Throttle staged. So, that makes it as true of an ACIS system as it can get. It has it all. The Crossover throttle angle is 60%. with engine speed a 4200 rpms... which means....
10% throttle, 1000 rpms === ACIS valve open
10% throttle, 5000 rpms === ACIS valve closed
100% throttle, 1000 rpms === ACIS valve closed
100% throttle, 5000 rpms === ACIS valve open
I'm pretty sure thats EXACTLY what i said. Need proof???
thats a toyota diagram... more of those can be found on this site,
http://turbomr2.com/MR2/Reference/TVIS/TVIS.htm
...and i will dig and dig through my TIS computer and storage rooms full of Toyota Documentation at my dealership if you still can't face the fact that the 7m-ge has a 100%, full, true, toyota ACIS system. CUT AND DRY!
