1 - 2 of 2 Posts
In The Sonoran Desert
I pulled out my TT waterpipe to replace with an NA one. I noticed there were two versions : 16278 - 46010 for 93-97, and 16278 - 46040 for 97-98
I bought the 46010 and noticed it was quite a bit longer than the TT layout
257966
257967
Im not really concerned abo this as I imagine being closer to the firewall will move it away from the DP. I also assume that I can use the same hose seen cut, I think the C87725
I was wondering if anyone knew of any differences in the two versions or if it iust toyota renumbering things after a model year. Is there a better hose to use?
Discussion Starter · #2 ·
I should add the 16278 - 46010 is anywhere from $67 to $80 while the 16278 - 46040 is around $40-50
1 - 2 of 2 Posts
