1 - 3 of 3 Posts
Car is a 95 na. Ac was working just fine the other day, no issues what so ever. Today I go to turn on the ac, and nothing. There is no power at the ac plug, checked all the fuses under the hood on the dr. Side fuse block as well as the fuses on the driver side kick panel. I didn't see a ac relay though, unless it's the heater relay? All my hvac controls seem to be working properly. And when I ran the hvac diagnostic check I got this
7 Foot/Face: Open or short in ambient temperature sensor circuit
10 Front Demist: Fault in solar sensor circuit. (Might be normal if in dim light conditions. Try again while in bright sunlight, or shine a torch into the solar sensor at the base of the windscreen.)
Anyone have any advice?
1987 Supra Turbo R154 Pearl White, Blue Velour
My 87 (and an old 84), had a resetable relay under the passengers kick panel. A paper clip was used to reset it. In the end, both needed new compressors anyway, and that was causing the circuit to trip.
1 - 3 of 3 Posts
