1 - 20 of 35 Posts
Moderator, l337 M0d3r4t0r
Ok as most of you know i have 3/4 of a harness between the JDM one i got with my engine and the 1JZ-GE harness.
I need to know what these wire colours connect to and what these connectos refrence to on the 1jGTE harness.
Take a look thanks.
This is the fuse box wires I believe, I need to know which wire does what!!?
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0731.jpg
Also what does that blue connector hook up to?
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0734.jpg
These connectors are from the 1JZ GE harness where they would normally go to the fuse box. What connectors are these if they are on the 1jz GTE and what colours and orders do you have on your harness?
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0737.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0738.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0740.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0744.jpg
These are the wires for the connectors above
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0745.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0746.jpg
These connectors are where the ignitor hooks up. Can someone tell me the connectors and what? I know the ignitor one however, the rest I'm lost at also please tell me the wire colours you have on your harness so I can match them all up.
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0747.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0748.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0749.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0750.jpg
These are the wire colours of the connectors above.
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0753.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0754.jpg
http://www3.sympatico.ca/zazzn/pics/temp/harness/IMG_0755.jpg
ma70-7m=1JZ
The total length of my harness is 113" from the longest ecu plug to the end of the last coil pack plug. That is with it just laid on the gound and spread out. My harness was lengthned 18".
The blue connector is for the VSV undernieth the intake manifold.
ma70-7m=1JZ
All the harness wire color, info, pinout are on this website http://www.1jz-gte.us/92Supra6.html .Are all the plugs cut off the harnes?. You should be able to just match up the color from the back of the plug to the colors on the harness.
Take a pic from farther back so we can see thw whole harness and whats missing.
woah...uhm...good luck man...:ugh2:
Actually I dont even have the plugs. I was planning to chop on ones form the GE harness but they don't have the same colour code.
I was looking on the site above for wire harness colour for each wire but I cant find it.
***http://www.1jz-gte.us/documents/SubDocs1/WiringEFI.pdf***
Found just need to know what connectors go on the end of the harness
Whats the sensor in the 11th picture?
BTW can anyone help???? Picture 1 and 2 are the GTE harness where the wires where cut.
Picture 3 are the connectors I have form my 1jz GE harness... I need to transplant them over but I don't know the pin order so thats why i need pictures from your harness!!!! PLEASE!!
JZA70 or go home!!
ma70-7m=1JZ
I will try to help you out tomorrow whem I have some time. So you have a cut 1j harness, without plugs and you want to use your 7m plugs, correct?. Or do you have a handfull of cut 1J plugs without wiring ?.
I have a cut 1j harness and no plugs. I have another 1jz GE harness that has MOST of the plugs I think I need but the colour codes are diffrent.
So I'm going to use them but I don't know which go where becuase I didn't know the pinouts.
i <3 supra
picture #10 looks like it connects to the ignitor, its too late for me to go check cause im lazy like that, but when im cleaning up my motor tomorow ill go look and make sure
You still looking for help?
ZaZZn said:
actually yes.. I havne't had a chance to touch the harness still but.... yes..
What do you know, and what are you still searching for?
Discussion Starter · #18 ·
haha nothing i'm just bitching because it's not done..
It makes this pretty simple then if I dont need the fuse box... I'm going to pull all the wires form above OUT of the hrness....
What where all the wries for?
Just looking at them.... probably the 1JZ fan, a little for the A/C some for the ignitor and maybe a few others off the top of my head.
Discussion Starter · #20 ·
well don't I need them for the igniter? also I was planning to keep the AC...
I completely disasessmbled my AC compressor for my 1jz as I though it was sized however, it was just a little tight due to water that got in there at some point.. pistons have a little scoring but should be fine when I add new oil and R134 or R12A... R12A rocks.. my friend got -6 out of his PS on a dodge colt!
lol
1 - 20 of 35 Posts
