1 - 7 of 7 Posts
Hey guys
After my 1J swap the motor idle for about 5-10 min then shut off and won't start back.
I'm getting no spark.
I want to check my ignitor and jza70 ecu on your car or if anyone is nice enough to try theirs on mine.
Thanks Advance
since you are in richmond hill maybe you should reach out to m&s performance to help you with testing the cpu and ignitor they are in saint albans. my guess is its a bad ecu the ignitors are normally bullet proof but the ecus go bad all the time have it checked, if it is a bad ecu you can send it to driftmotion.com to be repaired.
if the ecu is fine then maybe you got a bad ignitor after all ,the ecu,ignitor and the crank sensor controls spark on the 1j and 2j how about your wiring is that ok?it could be a broken wire also.
1 - 7 of 7 Posts
