I installed my GReddy Type-R BOV in my Typhoon. The vacuum line source is the intake plenum and goes to the top nipple. The lower is open as directed by the instructions. I loosened the not and backed the threaded bolt out all the way and then replaced it until it just started tightening up, meaning it should be all the way loose, right? Well, it will NOT vent air under any circumstance light boost or WOT full boost (~25psi) and I'm still getting compressor surge. I want to make sure all my connections and adjustments are right before I go back to the place I got it from. I requested the standard spring when I ordered it but it's possible that I was given a stiff spring.
So, any input would be greatly appreciated.
