1 - 20 of 22 Posts
I acquired a 95 NA recently automatic .. the car runs perfect .. but sometimes randomly the o/d "overdrive" light flashes randomly and it wont stop till I shut the car off .. the transmission seems to shift every gear fine .. nothing out of the ordinary I can sense so far .. I hope its not a big problem .. if anyone could kindly help me out .. thanks .
There could be a couple things.... for the sake of your happiness on the forums.. Search before posting...
These will explain your question an answer.. If you dont find an answer in that then state what you found and get more specific with your problem..
Till then search b4 posting..
O/D Blinking Search
well I searched I found similar problems being posted on this forum .. but no clear answer basically if you look at the supra manual it says to take it to toyota as there might be a problem with your transmission .. its vague .. as far as the full service manual .. im just gonna have to get a hold of one and see what I can find .. its just really weird .. and im freaked out a bit hopefully its nothing big .. I have heard people before saying that basically your transmission might get toast or something .. anyways ill keep looking and probably take it to someone .. thanks
Have you tried to pull any codes out of your ECU? You should still be OBD1 so all you have to do is jump 2 pins in the diag box then read the codes on your check engine light. www.mkiv.com tech articles is one of the best resources you'll have.
could be your speed sensor. Could be a couple differen things. try and pull codes and if you need the manuals IM me (On aim: Roliks143) after 5pm est and I'll get em to ya.. warning. I will not send it over Dialup as it would take 2years..ok I exagerate but it would take forever.
OBD1 directions and codes
dude you are talking to me in rocket scientist lingo .. how do I jump 2 pins .. I see the little grey diagnostic thingie below the dash .. ill figure it out ill have to read this a few times .. lol
thanks for your help ...
Go to the website I linked in my previous post with the OBD1 directions and codes.
It will show you what to do and how to read it..
BTW YOur diag box is on your firewall in the engine bay. should be twards the passenger side.
Very Senior Member
Right - read the link.
Also - we have a diagnostic box below dash on driver side too.
Come on guys! The obvious answer to the question is THAT THE GOD DAMN TRAC FUSE IS OUT! Every auto that has their track fuse pulled has their O/D light flash when their O/D is button is pressed in. Look in your fuse box under your hoood and see if there is a 7.5 amp fuse where the diagram shows "TRAC". If not, there's your answer. Nothing wrong at all. Just a side effect from pulling the TRAC fuse.
I'm a chump when it comes to doing my own work but the very first thing I ever did was pull the codes. Trust me, if I can do it, then anyone can!
Pull the code, with the code at least you know where to start. It could be the speed sensor, odo, trac relay, abs and worst scenerio --- the tranny
kevinb6876: BTW his car is a NA, no "TRAC"??? correct me on this if i am wrong
Discussion Starter · #16 ·
yeah it doesnt have .. trac control .. by the way .. I sent roliks a pm .. my brother somehow reset the ECU .. he said to me not to worry about it and that it should be fine now .. I dont know .. it seems to be fine for now .. hopefully it wont appear again .. I have driven about 80 miles since I had it reset no sign of the flashing again .. thanks for your help guys ..
*SNICKER SNICKER*
I'd be willing to suggest that did not fix it. And someone in here also suggested that it is because the TRAC fuse is pulled? OMG please, anyone with 1/2 a brain can check to see if the fuse is OK! Trust me it's not the TRAC fuse... I have been having this problem, intermittent for the last 3 years and I am SO sick of it. I have had 4 tranny guys look at it, pulled codes, replaced speed sensors, and it's STILL NOT FIXED!
1 - 20 of 22 Posts
