sorry to post this twice but i wasn't getting anyresponses to the other one. i was just doing front brakes on my 93 turbo and the problem is that i got the outer pistons in and got the pad in but the 2 innter pistons won't go in. WHAT DO I DOOOOOOOOO?????
Moderator
Push harder. You may need to use a piece of wood to pry back the pistons.
Later, Steve
well thanks for the help, i tried all of that and it didn't work...sorry so then i turned the piston to see of it was jammed and it wasn't so i tried to get it in again and it went in w/ no prob and thanks again for the ideas
S
take the pads out.. make sure that u have not taken the whole piston out of the caliper.. it might have an small offset u can't see due to the plastic dust guard and that's why u can't push it in.. do this carefully.. once u make sure it is in the caliper, u can use a large C-clamp to push the cylinder in.. hope this helps
