1 - 4 of 4 Posts
· Digital Dreamer
I need help removing the oil dip stick tube that runs into the side of the block and into the pan, and removing the oil filter unit attachment point on the side of the block. The thing you screw the filter into. I need these both out by tomorrow aft hopefully cuz the block is geting hot tanked by my machinist.
thank you all in advance,
eric
· 7M POWAH! baby ;)
the easiest way i found for the dipstick, drop the sump, get a hammer... smack it out
i'm assuming ur talkin bout the oil pump housing... undo the 24mm? bolt in the center of the unit then give it a bit of a wiggle and she should come of
hth :)
· Digital Dreamer
shit! I knew that bolt had to come off
Now I have to go buy a socket for my 1/2 breaker bar. I tried using a regular ratchet and hammering it on that bolt, but it didn't buge, not even a milimetrical turn. I was pissed. So, I can just hit the bottom of the dip stick tube on it's inside the pan end, and it will pop out from the inside out? That soudns easy, I will try it tomorrow, unless someone corrects it and says I wil lruin it that way.
Thanks for the tips :)
eric
· 7M POWAH! baby ;)
well it will flatten a bit lol... but you can soon straighten it out ;)
1 - 4 of 4 Posts
