Hi i have a problem i cant figure out, when my throttle position is at just exactly 8,5% it goes fast to the lean area and stumbles, if i give it less throttle ore more it goes back to normal, its just at exactly 8,5% i cant really get whats causing this, ive tried changing it in the fuelmap and also in the injector throttle table at that exact tps posistion but nothing changens.
I cant see anything wrong with the fuel accel either.
It dosent mather witch gear ore rpm ore load im in its at that exact throttle position.
And the marker in the fuel map blinkes and almost dissapeers,
My setup is
Supra Mkiv
its 72 turbo
hks 272s
1680cc injectors.
E85 driven
And so on.
I will try to get the map posted abit later on dosent have it on this computer.
Hope someone has a idea what could cause this, ore where i should look to find the problem
Regards Anders
My setup is
Supra Mkiv
its 72 turbo
hks 272s
1680cc injectors.
E85 driven
And so on.
Regards Anders
