1 - 9 of 9 Posts
Who has done 12V Fuel pump mod for their NA-T?
I'm planning on rewiring the fuel pump ECU to run on 12v mode at all rpms. The tech article on mkiv.com states that there are 2 operation modes for the twin turbo supra ( http://mkiv.com/techarticles/12v_mod/12v_mod.htm ).
I was wondering if the same 2-mode function also applies to the NA supra's fuel ECU?
I'm going to spend the weekend on my TE-44 turbo kit tweaking my a/f ratios with my LM-1 wideband and SAFC2. Is the 12v mod necessary to maintain consistency out of the walbro fuel pump I also have installed? I'm not seeing any lean spots on my a/f gauge at WOT between 4-5K rpm like the problem in the tech article states but i figure I ought as well try the fuel mod to see what will happen and hope I can get some input from those that have done this mod and what differences you noticed.
Last Question :) : The car was professionally-tuned months ago and now my LM-1 is showing a consistant a/f ratio of 10.3 on WOT so I want to try tuning the car on my own to lean out the fuel a bit. At Hi-Throttle setting on the SAFC2, should I shoot for an a/f ratio of 11.5-12.0 from 3500rpm+ or should I try achieving those #'s starting at a higher or lower rpm?
Specs on car: Stock compression, 330cc injectors, with a TE44 turbo that starts boosting at 2000rpm and hits full boost of 9psi at 3500rpm. Thanks in advance guys, the search button is not working at this time :chicken: .
~Chris
Addicted to Boost
I was wonderig about that 12volt mod as well. I also have a question for you, Howd you go about getting that cap to fit tightly on the fuel tank after opening to do the pump. When i tightend my cap back down, the center part that has the pump hanger hanging off of it still floats and moves freely... i cant seem to get the cap to go down any further. You have any tips?
Oh and isnt that pushing the limits of your motor at 9psi with stock compression? i mean, id be careful.
TE44 NA-T
Are you running off of the wastegate spring? If so, what psi spring?
I'm running off the wastegate spring with some boost spike at WOT.
I hope to get some input whether or not to give this 12v fuel mod a try.
TT This
I have the 12v Mod done. I've been running it for a few years now. No problems with it at all. If I remeber correctly you should be able to follow the MKIV write it and you'll be fine.
Discussion Starter · #6 · (Edited)
I just took a look at the Fuel ECu that the NA supra has and the ECU is different then the TT supra ECU. I also have the diagram for the 2jzge fuel ECU and it shows a different type of ECU on the NAs then what is pictured for the TT Supras. The connector is also in a different position. I'm guessing the NA supras do not have 2 modes of fuel operations like the TT does. If anyone else has another viewpoint, please let me know. As of now, I'm aborting this mod.
TT This
Well....I did the mod a long time ago. I followed the MKIV.com write up when I did it...I guess I don't know what to tell ya. It's been fine for me
Nah, the search function finally worked for me; I did my research on everything talked about with the 12v mod and the results are very mixed on its effectiveness. Some said it helped with their lean spots; some said there was no effect at all; some said it makes the fuel pump run hot for a longer period, causing the car to run leaner after a while, and one person had a small fire on the fuel pump ecu. My car isn't having any lean issues with the walbro pump, this mod is something i thought i would do just for the heck of it.
TE44 NA-T
I asked Dave H if i had to do the 12v mod. with my walboro. He said it wasn't necessary.
1 - 9 of 9 Posts
