1 - 7 of 7 Posts
ok, on my uncles 88 n/a mk3 the bottom hose on the isc valve is leaking coolent through a slit in it, i have the replacement hose but how the hell do you get in there to get the old hose off? ive tried a search and the tsrm but cant get anything, if anyone could help it'd be appreciated:mad:
20G Boostin'
you mean the coolant hose that comes up from beneath it? just remove the ISC, then replace that hose, getting to the bottom of it to clamp it on is a bit of a pain, and you may need to move the TPS to get more space to work with
and while you are at it, trace the gasket for the ISC valve on a sheet of alum, and make a block off plate, its real simple, and you have less bs in the engine bay.
1 - 7 of 7 Posts
