·1st question: Can I go anywhere to get my ECU trouble codes or where and how can I read the ECU trouble codes?
2nd: I went to TTC using the plastic valves and after 20 minutes of driving the check engine light came on.
So I went back to sequential.
Then I tried it again and the same thing happened so I went back to sequential!
Now I tried the ETTC mod and everything was perfect until after 20 minutes of driving in TTC and/or sequential the check engine light came on again.
Could it be the pressure tank or ( the ehaust by pass valve
which I did not cap off)
I want to leave the check engine light on and see what the trouble code is.
Please anyone experienceing this PITA $hit?
Any suggestions or comments are greatly welcome!
