1 - 4 of 4 Posts
wut
Here are the symptoms: I get a clicking noise coming from the right rear tire when going in reverse (especially while appyling the brakes) and also sometimes going around curves at slow speeds. The noise is pretty loud and almost sounds like a brake pad is getting caught against something.
I had my car on a lift the other day with the tire off but couldn't find anything abnormal with the brakes. Is it my wheel bearings? Anyone ever have this problem before? Thanks for any help.
I had a clicking noise coming from the driver side I was about to replace the control arms but I jacked it up and could not find anything so I replaced the wheel bearing and seals and is went away it would make the noise under a load forward or reverse like a creaking noise.
hope this helps
laterz
wut
Cool thanks for the info. I was thinking thats what the problem was. Anyone else have any suggestions.
1 - 4 of 4 Posts
