you don't have the EGR system. what are you doing to it?
check and see what fault is coming back. if it's for the egr sensor then yeah that will fix it . So make sure that it's not something else.so i have the jdm block with no egr valve.. i tried pluging the resister inside the harness clip... but i dont know if i plug in the right ones... has anyone done this before? my light keeps comming back up.
oh yea, you do have the EGR there, just not hooked up. i will take a picture tomorrow sometime. i think there is only one plug there, anyway. its next to the EGR valve.its throwing code 71 , egr valve. i have a jdm block with no egr.. i dont know which clip to put the resister in because the picture on mkiv.com is not working...
haha u plugged the other side going to the sensor didn't you?
Plug the one with hair around it. The hairless one will throw a trouble code.
Do you mean "Lambs wool"?Plug the one with hair around it. The hairless one will throw a trouble code.
