Guys and Gals,
I'm trying to finish the single Turbo install and want to badly clean up the engine bay because of all the vacuum lines and junk that was left over. Can any of you people help verify what I can take off?
Is that a direct intake manifold pressure line? Can I remove the 2 diaphrams? Is the breather suppose to be in there? Can I remove the box with the big arrow pointing to it?
Can I remove the canister? I think this is some kind of Emissions device. Are those lines considered vacuum lines or pressure lines from the manifold?
The unused harness plugs that went into the Twin Turbos can I cut those off? I don't plan on going twin stocks again.
Thanks in advance,
Peter
Hope you guys can help so I can finish all the stuff today. THANKS
Thanks in advance,
Peter
