I have a 93 tt 6spd...i got the car with no vsv sensors and all the acutator doors wide opened. I put all the stock parts back and now the car doesn't want to go over 5psi...its starts to build but then it cuts off and the car goes lean...so I search around and found a greddy fuel cut on top of the ecu and I thought I found my problem but the car still does the same thing. It keeps on cutting the boost...im thinking that I have bad vsv sensors? I air leak? If you guys can help me I will really appreciate it...thank you.
