I need an advise on how to take of my oil pan from the car. I did try to rise the engine but it need to rise to far up. is there any other method i can use to make the work liltle easier. Thanks
JZS161 Aristo TT
Why do you need to remove the oil pan :1poke:
Option #1 Remove complete engine repair reinstall How to remove engine
Option #2 Remove complete front sub frame repair reinstall
How to remove sump with engine in place *hint leave the brake calipers with the body*
:rockon:
HAHA....... the jack sliped and the car fall on it.
MKIII Owner and Dam proud
Remove the engine is the safest way. Then while you have it out check and do complete reseal.
