1 - 3 of 3 Posts
I have a '95 Non-turbo.
Went to Toyota because I was having problems. My power steering pump was going bad because of a leak in my rack and pinion. Also when I was in stop and go traffic, when I would just put a little pressure on the gas my car was shutting off.
This is what they told me.
Part#------------Decription--------------------Price----------Labor
44320-14240-----Power Steering Pump-------$356.22--------$266
44327-26020-----Gasket----------------------$ 3.91
44250-14240-----Gear Assembly--------------$815.03--------$456
2812-------------Oil-------------------------$ 11.97
25870-46010-----EGR Modulator---------------$ 71.05-------$ 86
83181-24050-----Speed Sensor----------------$ 207.45------$175
-Now, what I would like to know is if those prices are resonable or can I get things for cheaper from anybody else ?
-Also, to fix these things on my own with a friend, would it be a hard job and is there information somewhere that can tell me how to do it ?
-or, should I just cash advance and say screw it and do a full swap to TT ? Which I was planning on doing in like 6 months anyways.
Please give me some feed back !!!! My email is [email protected] .
Email Curt Aigner of Elmhurst Toyota, he gives great discount on parts. You can replace these parts on your own, purchase a Supra repair Manual from Curt. It will guide you through the whole process, enough information to take apart every bolt on the supra (almost). Save your labor fees for the manual.
Curt's site
http://www.supraforums.com/forum/forumdisplay.php?s=&forumid=100
Curt's contact:-
Curt
630.279.2265 parts direct
630.835.0122 parts fax
[email protected]
Good luck!
Choon
Is the ring and pinion for the N/A the same for the TT ? Or will I have to replace that anyways even if I do the swap ? ... will a new one come with the tt motor basically is what I want to know ?
1 - 3 of 3 Posts
