need help with the RPM wire from ECU loom.
2K views 1 reply 2 participants last post by  82 Rolla SR-5
#1 ·
hi guys
i need help with locate the 2jzgte RPM wire from the wire harness from ECU . a buddy helping me installing microtech system. he asked me which one is the RPM wire.
i did a search i get either pin 58 on B HARNESS or pin 16 on E10 A HARNESS.
the car is a J spec right hand side with 2jzgte engine.
thanks !
#2 ·
hi guys
thanks !
There are two separate RPM signal wires.
One comes from the OEM Ignitor and goes straight to the DLC1 connector in the engine harness (Black Wire / IG- Terminal pin). The other goes from the ECU to the gauge cluster tachometer via E10 - 16 (Black Wire with White Stripe / TACO Terminal Pin).
Text Plan Technical drawing Floor plan Diagram
