1 - 4 of 4 Posts
When taking plugs from the thermostat housing I pulled the orange plug on the top and must have pulled too hard. When I pulled this plug the wires came out of the connectors.
Question is, what is this plug to, and is it neccesary? If so, does someone have both ends of the plug, some extra of the wires from the harness and the bolt its connected to from a parts car?
Thanks in advance for any help possible
...heading for 500+ RWHP
Never really messed with my thermostat yet so don't quite know what you are talking about but...if the wire simply pulled lose from the connectors can't you just put/rewire them back in? Check the TSRM online for help.
I would except the, wires actually came out of the plugs, its hard to explain, i will try to get a pic of it up in the morning after school.
Just some guy
If the wire came out of the actual metal pin, you should be able to remove the pin out of the plastic plug. Theres a little plastic latch on the plug that holds the pin in. Strip the wire back, open up the rearmost clamps on the pin, and solder the wire back in.
Christian
1 - 4 of 4 Posts
