1 - 10 of 10 Posts
Found E85 NOT in NJ!
I am utterly baffled by how exactly to go around doing a power steering reloation
After looking at the power steering pump, I saw the actual thing i had to relocate, the black can, however it looks like only one hose is coming out of it
I have heard people saying that i should get a power steering off of a camry or something but I have no idea what year or model
Can someone please explain what to do
P/S Pump
I had done this mod on my NA-T its easy. First get the top fitting off of a tt pump (feed side)and weld a 6 an fitting on it. Next get a tt resivor or someting similar and route the lines to it. I welded a 6 an fitting to the bottom off my resivor and located it next to the brake master cylinder. The return line will just have to be extended and clamped.
About how long are the lines going from the pump to the canister? would you have a pic you could post showing your setup? interested in seeing it cause i am having a prob with mine. Also, where did you get the tt top fitting for the pump??
Fitting
I ordered it from Toyota, other cars use this type of fitting too.I will have to take some pictures. You might be able to see the ps pump in a tread about my intake.
Intake pics
You can see the fitting on the ps pump if you look close(2jzge intake manifold tread). I will take better pics later.
i see it... and you have had no issues with the power steering since this setup correct? its working 100% ?
Well at least i know the canister can be relocated that far away then.... i was hoping that far distance was the problem i have but you just shot that down. haha
thanks!
1 - 10 of 10 Posts
