1 - 2 of 2 Posts
Will work for Supra parts
I'm firmilar with the differences of mass air flow sensors and manifold absolute pressure sensors, and given some past experience and knowledge of MAP systems, I can see why it's prefered for the Supras running signle turbos. The problem is I can't seem to dig up any good how to's for converting to a MAP system on the forum here. I gave the search a shot, but it didn't give me what I'm looking for.
Can someone enlighten me? I'd like to know what's needed for such a conversion, what it all involves, and how the MAP sensor is integrated with the Supra's electronics. Where can I buy the stuff the I'd be needing?
In order to convert to a MAP based setup you have the following options:
Piggybacks computers like:
HKS VPC:
MAP ECU:
http://www.mapecu.com/merchant/mapecu2.shtml
OR
A Full Standalone ECU:
AEM EMS:
No matter which you choose, you will have to tune your car in order to keep your air/fuel ratio in check. Do a search on any of those specific units to learn more about them. It has been discussed thousands of times on the pros and cons of each.
1 - 2 of 2 Posts
