1 - 13 of 13 Posts
grey "toyota"-#75441-14190 <-- rear hatch emblem?
grey "supra"-#75442-14280<-- rear hatch emblem?
grey "logo"rear-#75471-14010 <--rear center hatch emblem?
rear non turbo brake pads #04466-30030
front non turbo brake pads #04465-14081
rocker cover gaskets (mines leaking so need replaced)
extension housing seal (also leaking)
hatch rubber stopper #67293-14051
Toyota Fuel Filter #23300-49195
and total shipping of all them parts to australia 3171
also can i get a separate priceing on the rear hatch strut that holds the hatch up so i can purchause at another time thanks curt
75441-14190 Plate, List 12.38 Cost 9.15
75442-14280 Plate, List 18.58 Cost 13.74
75471-14010 Plate, List 17.81 Cost 13.16
04466-30030 Pad Kit, List 58.21 Cost 42.61
04465-14081 Pad Kit, List 58.21 Cost 42.61
11213-46020 Gasket, Vc List 13.53 Cost 10.00
11214-46011 Gasket,vc List 13.53 Cost 10.00
90210-07001 Washer,vc List 2.03 Cost 1.50 X 16
90311-38032 Seal, Ext List 8.57 Cost 7.32 [w58]
67293-14051 Cushion, List 5.20 Cost 3.85 X 2
90159-50116 Screw, List 0.63 Cost 0.47 X 4
23300-49195 Filter List 28.10 Cost 20.77
Shipping 67.50 Approx
68960-19585 Stay Assy List 137.84 Cost 101.93
68950-19895 Stay Assy List 137.84 Cost 101.93
Shipping 42.50 Approx
i have mkiv with a getrag is there any difference?
sorry about the confusion as i though the w58 was a 5 speed or are they the same?
and can you confirm allll those parts are for a mkiv tt 6speed cause if theres any confusion i just have the shitty small brakes thats all
90080-31029 tail shaft seal list 21.43 cost 15.34 V160
90080-31032 shift shaft seal list 6.64 cost 4.77 V160
Everything else is correct.
so which 1 is the extension housing seal sorry curt this is very confusing for me aswell cause the mechanic didn't explain and when i called again today his stupid wife decided to answer for him which gives bullshit info cause she doesn't know (hows this she said when you put redline water wetter in with toyota red coolent it makes the coolant go completely clear) so thats an example of how much she knows anyways, are any of these 2 the extension housing seal cause on my report from the mechanic it says extension housing seal leaking so thats what i need. sorry curt i just wanna make sure i'm buying the right stuff since i'm down here in australia
90080-31029 is the extension housing seal.
90080-31032 is the shift shaft seal [ also known to leak in the same area]
Get both and play it safe!
ok noiw i get you just waiting on a reply from a mate to confirm weather any more parts are needed then i'll place the order should know in 12 hours thanks curt
Curt just wondering if u have any of the shift knobs like MVP? I know this was a custom production run for MVP but its worth a shot asking u seeing as we r already ordering something from u
BTW im the other guy his waiting for
Discussion Starter · #11 ·
75471-14010 Plate, List 17.81 Cost 13.16 X 2
67293-14051 Cushion, List 5.20 Cost 3.85 X 4
90159-50116 Screw, List 0.63 Cost 0.47 X 8
ive added a extra 3 items to the list as i'm ordering them for a friend so yeah with the numbers next to the items just thought id mention it, can you give me a quote number so i can call and give you the billing details like i did last time thanks curt
1 - 13 of 13 Posts
