Hey guys I'm trying to get a quote for shipping my engine and trans, I just need to know how much a 7mgte and a R154 weigh.. i need to know asap if anyone knows, I'll keep searching after this post but please help! :S
gte probably less then 500 lbs cause i have my engine hoist set at 1/2 ton and it does it with a breeze. also my engine stand is for 500lbs i think or maybe 1000lbs? but it holds up fine to.Hey guys I'm trying to get a quote for shipping my engine and trans, I just need to know how much a 7mgte and a R154 weigh.. i need to know asap if anyone knows, I'll keep searching after this post but please help! :S
that really sounds pretty reasonable to me atleast cause i take mine out like every other month for some stupid problem.so say, around 600 lbs for everything together, minus the ct on it? sound reasonable?
id honestly say its closer to the 700-800 mark really. its definitley under 1k because the hoist will hold them both on the 1/2 ton setting.Okay, i told them around 600, thanks for the help man![]()
this is true, but hey i guess you will find out when they pick it up?id honestly say its closer to the 700-800 mark really. its definitley under 1k because the hoist will hold them both on the 1/2 ton setting.
if i had to guess i would say around 750-800 fully assembled
The block is lighter than 150 pounds. I was able to pick it up without destroying my back and I am by no means a large guy. The crank is maybe 40-50. An assembled head might be ~80 pounds, but unassembled it certainly isn't. Turbo weighed ~22 pounds when I sent one out for an upgrade. Tranny is ~100-120.that really sounds pretty reasonable to me atleast cause i take mine out like every other month for some stupid problem.
rough guess of everything
a bare block is around 150
crank 60-80lbs
pistons, rods, water pump, crank pulley ~15 lbs
head 80lbs
intake/exhaust manifold 20lbs
clutch/flywheel 50lbs
turbo? 15lbs
tranny 150
