'99 Avalon xls - 1mz-fe
knock sensor, driver side taillight, and driver side piece of body (nonpainted) above the front wheel.
will be more to come
thanks
probably gona buy the knock sensors, ill pm you if i do
sorry lol, like the body panel above the driver side front wheel.. nonpainted because its a custom color and toyota doesnt carry it anymore
btw, just wondering if you could help, it threw a engine light, the scanner said its a misfire which it is because its obviously running on 5 cylinders right now cause it runs bad and not fast at all. its not a bad backfire or anything, you can hear it through compression stroke but it doesnt ignite. Already replaced the plugs, coils and wires and that didnt help. If you gimme the right idea ill buy the parts from you instead of the local stealership. bad description but maybe youve seen it before.
THanks
