I appreciate the feedback oldcrxbooster, but I did my own hacking in the past two days and here is a small solution to those who might encounter the same problem. Note that I am doing this until I upgrade intercoolers so it might work for some, others might have a different view.
The first thing I did was I used the 3 inch 90 degree elbow I primarily bought for the compressor housing, and used it on the endtank. After I did this I went to a local muffler shop where I had them cut me approximately 7 inches of aluminum 3 inch pipe.
You can see there that I used the "fender" pipe from the three row, turned it sideways and it mated right up to the pipe that was originally used to mate up on the end tank. I am using the greddy 2 3/4 to 3 inch coupler to mate these two pipes together, and I bought another 2 3/4 to 3 inch coupler from turbohoses, and that will mate straight to the turbo.
Here is a top view
Here is a top view you can see it mates right to the turbo. Like I said I had to order the reducer to make it snug.
Finally this shows the ground clearance since my car is DUMPED! After installing the coupler onto the turbo I will have roughly 2 more inches of clearance from the ground to the blow off valve.
So in conclusion the only thing I do not like is the placement of the blow off valve because it is sticking out right under the vent. Granted it will be louder but it will probably encounter some road debris.
So what you need to purchase for suprawillis's 3 row hack job are:
-90 degree precision turbo 3 inch elbow $30.00
-7 inches (give or take) of 3 inch aluminum pipe $20.00
-2 3/4 to 3 inch coupler from turbohoses $28.00
-misc silicon hoses and clamps if you don't already have them.
