I just installed an NA-T kit in my Lexus Sc300, all went well except the car was running a good bit rich and would stall out when putting the car into neutral (like running and then going to neutal to stop at a stop sign). At this point I could at least drive it around the block.
The car is running the larger lexus V8 MAF and Boostlogic 525cc injectors, I also have an SAFC2. I was told to install the SAFC and pull out 20 to 30% fuel across the board and it would help out.
SAFC went in and the car will not run correctly, the idle is choppy and the car is still running very rich even with fuel taken out...and running worse. I've double checked the wiring and it's correct, even re-did the wire taps. When that did not help I took the SAFC out thinking the car would return to being semi-driveable but its still the same.
I'm out of options and need the car back going, I would rather pay someone to come fix it rather than pay $175 just to tow it to a performance shop.
Is the SAFC2 gonna work for this application, someone mentioned that at idle or closed loop it would not pull the needed fuel.
Please call me at 678-588-3991 if you can assist me, I'd rather pay someone the tow truck money than have to send the car in somewhere.
Thanks,
Todd
Thanks,
Todd
