1 - 20 of 24 Posts
Just purchased a Greddy t78, Greddy 3 row Intercooler and WOTM maifold, now i need piping, BoV and Wastegate left to buy. Any brand/model i should go with. I wanna make my first single turbo experience a great one. Keep in mind im a Supra rookie.
· Suprasarous Y0!
Boost logic or sound performance down pipe. You could save some money with an eBay midpipe... Not going to matter. Then pick an exhaust you like. Pick a bov which sounds best to you with a tial 44 wastegate.
650 whp+ go with 3.75 inches +
i have the Greddy Down and Midpipe, the Greddy Intercooler i bought didnt come with piping. Does the intercooler piping have to be top of the line? I currently have an Apexi N1 exaust.
· Suprasarous Y0!
If you dont already have intercooler piping, then just bring it to a shop and have them do it. Chances are there will need to be some welding and cutting to make it fit perfect.
Very cool, thx for the advice. Hopefully my Supra will be ready for the next meet.
· (Rare & Unique)
1/2 correct newbie.
Boost logic turbo manifolds are Greddy based
Sound performance/WOTM are HKS based
-DP's will be DIFFERENT
You can probably get the matching Greddy IC pipes in the FS section @ a good deal with the cold side being a direct bolt on/standard for stock IM. Hotside offers 2 options but in your case, better off drop down (Gredy 4 row style). Good news for you, if you get Greddy IC pipes, it's all bolt on :) - If not, custom pipes as mentioned by the fellow above.
WG- you have a V band flange so just pick up a 44 gate (Tial-most prefered, Precision)
WG spring depends on desired boost level (~1 bar or less)
BOV- your choice (Tial 50mm, HKS)
· Suprasarous Y0!
If you call boost logic they will make you a DP to fit a HKS based manifold newbie. This is 2011 not 2006.
The OP is better off just having a shop do 4 row style piping. It will look much better, TINY bit better performance and more than likely cheaper or the same price as a used beat up pipe kit.
· (Rare & Unique)
Says the "modern" guy who just went single....welcome new B
& I was reffering to a BOLT ON 4 row greddy IC pipe setup, which works perfectly for him.
· Suprasarous Y0!
· (Rare & Unique)
Your sticker .. Are you asthmatic ?
· Suprasarous Y0!
· Suprasarous Y0!
· Suprasarous Y0!
· Suprasarous Y0!
^ It means Original Poster... referring to YOU!
1 - 20 of 24 Posts
