1 - 16 of 16 Posts
ok, check where the wastegate acuater(in the front of the turbo) (don't know how to spell it) is and check if that little hose is connected; then check to see if the vacumm line that runs in the front of the motor is connected to the power steering like needed; then once you get the accordian hose back on make sure that the little hose is connected to the bottom of the accordian; also check if all the vacumms are correct for the heater accuator...
AFM, make sure its plugged in. thats what happens when the afm is bad/no connected, it idles but as soon as u hit the throttke itll shut down.
Discussion Starter · #11 ·
ok still the same but i was getting the code 24 31 52 and i change the afm and i put the lexus afm from my other car still the same it rap up good but when i leave the gas paddle it will come to about 500 rpm and sputter and shut down
DRiFTT
definately AFM, dirty, bad, maybe both going bad or not working? wiring to the AFM rigged?
DRiFTT
^^run thru the wiring to the jack that goes on the AFM, see if theres any point where it may look rip, burn, pulled etc.
Boost leak? Check your IC pipes. A huge leak will allow your car to idle, but when you try to go, it'll just die on you.
It'll throw a bunch of codes at you too. I didn't bother to check the codes though. Most of them are worthless.
1 - 16 of 16 Posts
