1 - 8 of 8 Posts
1. My door locks don't work , i look at the TRM and found the wire diagram for door locks/anti theft , checked the fuses to the Immobilizer ECU and they all have 12v , they all look good , i checked the switch at the door , and according to the wire diagram its a ground signal to the anittheft ecu. The switch has continuity when i [res the button so i know its working .Now here is my problem. I looked at the component locations and i saw the pic were the ECU is suppose to be but i cant seem to locate it . So i was wondering if any of you could snap a pic of the ecu for me of were its hidden , i have a feeling they took it of the car.
2. this is driving me nuts , i installed a new ACT PP with a HPF disc , stock flywheel resurfaced , new pilot bearing, new through out bearing with new snap rings . I get this weird metal to metal noise at idle. When i depress the clutch 1/4 of the way noise stops . I took the tranny back down , inspected the input shaft bearing , and everything installed and i noticed that the throw out bearing doesn't sit snug . Like i can move it slightly side to side. I noticed that on the stock PP it didn't do this so im guessing this is the problem but i wanted to check if any of you had the similar situation. I searched and found 1 similar problem but eh guy hasn't got back to me via pm.
· The Great Kruso
1. Define "door lock doesn't work", the electronic door lock mechanism that automatically locks and unlocks your car or you physically are unable to lock (secure) your car due to some hardware failure?
2. Throw out bearing needs to be replaced. Where did you get the TO bearing that's in the car right now?
1. Auto door locks , you know the switch on the door that unlocks the doors . I think the ECU is missing.
2. Got it from Toyota
· The Great Kruso
1. Have you changed the master switch located on the driver side door panel?
2. If you got it from Toyota and this one has more play in it then the original one that came out of your car then they gave you the wrong part. Verify the part number.
Discussion Starter · #6 · (Edited)
1. switch works , i wanted to check the signal from the switch to the ECU but i couldn't find it .
2. its possible but stupid me i threw the old parts away along with all the new part bags.
Discussion Starter · #8 · (Edited)
i was looking at the wire diagram again and i think the ECU is there now , but i just cant find it . I looked at the location were its suppose to be and its not there .i did find the 2 connectors for it so ill probe for signal there , maybe its behind all that crap on the pass kick panel.
1 - 8 of 8 Posts
