Trying to time my 7mgte after replacing the theromostat housing gasket.
I followed the TSRM and found TDC with the cams aligned and crank mark at zero with cam under the oil cap in the proper position. I even seen the pictures of the cps and its in position. Car starts and runs fine, but I can't get the timing to 10 degrees with the jumper wired in the dianogtic thingy. Actually the jumper does nothing for the timing, the car just idles at around 1100 rpm in "N" and can't be adjusted lower the 15 degrees btdc. Any suggestions?
Regards,
Chris
Regards,
Chris
