1 - 16 of 16 Posts
well all good things must come to an end...
i need the car smog... so i will be restoring it to full stock... :freak:
anyways any trick and tip that you guys wanna share to help me get a higher percent chance of passing the smog?
i know that you need to drive the car right b4 you smog it to heat up the cat but thats all i know....
For CA just have all emission stuff back in, all the vacuum hoses correctly and good cats and a good running motor and your good.. aight peace :chicken:
btw, moved to CA section
Old School
A stock twin car in good mechanical shape, using the stock DP, all emmissions equipment installed and functional should have NO trouble passing smog.
Mine's been smogged 3 times now. Two times with colder plugs. Still passes with a lot of room to spare. No extended driving to heat up the cats.
although technically illegal b/c you're changing vacuum hoses, i passed TTC w/ stock exhaust, airbox, & EGR. the hoses are so complex i don't think most shops care (or even notice) as long as you pass visual on everything else.
also, to echo lagtime's comments, once i fixed my EGR hoses, i passed w/o much trouble and the car sat cold for at least 1 hour.
2 things:
- there was a small crack on the underside of a hose
- the routing per the FSM is incorrect
MSB for Life! :D
smog is only once every other year right?
from the people ive asked, ive heard once every 2 or 4 years, but i just got another smog notice for this year even though i smogged last year. did the dmv make a mistake?
MSB for Life! :D
RSA Supra said:
It's every 2 years. You get any tickets recently?
Nope, ive been clean since '03 for tickets (knocks on wood), and that was in my civic anyways.
so it is a mistake?
1 - 16 of 16 Posts
