"proefi traction control" on youtube nets several results.Any vid for the traction control in action like in the drag line ?
Why did you sold your RLTC ? it wasn't that good ? is Motec TC better ?Had RLTC sold it and my ecu for a motec m800
Thank you for the linkhttp://www.youtube.com/watch?v=xa-YzFXm8Js
At that time it was a drag radial record!! Over 2500 HP on a drag radial all controlled by ProEFI traction control!!
BTW I saw the vid and later onn I found two vid for the same guy, his name is Paul Major and the something which I saw it's little confused. The vids which I found Paul Major had crashes on his vett
So does the ProEFI in his car and had those crashes ? I think they are in his car and still the car slipped and hit the wall
I really need someone to clear this one for me please
Indeed.TC will not make you into a racecar driver, it still takes skill to keep it straight
Here are the links below :
http://www.youtube.com/watch?v=pkj8xN0rjvc&feature=related
http://www.youtube.com/watch?v=oznXoUVsuC8&feature=related
Indeed.
You are assuming the traction control played a role in his crashes. Traction control as discussed in this thread assists the driver in getting the most out of the car. It is not a safety nanny that prevents accidents, although it can do that in the hands of a skillful driver. My position regarding the MoTec traction control is the same as it is relative to the ProEFI. No proof exists that it is better than the RLTC, nor is there proof, to my knowledge, that the RLTC is superior to the ProEFI or the MoTec (I believe the RLTC is superior because of its pedigree and how it was developed, but I have no proof of that). Having observed the effectiveness of the ProEFI many times when personally watching Saad Saad run a bunch of 8-second quarter miles, I am quite impressed. That said, the vast majority of RLTC guys are road racers and I am just as impressed with the RLTC in this type of racing as I am with the ProEFI in drag racing. That's why independent third party proof is needed before someone can say unequivocally that one system is better than another. q8 Supra, I am not sure anyone can help you with your decision. It seems as though you are more into drag racing. If this is the case, it would be hard to argue against the ProEFI based upon what I have personally observed. Good luck with your decision.
Ken.
Can you show us the result, and how is it with you ?im going to finally wire mine up this weekend
Sure, hopefully it will work well enough so I can walk a certain trash talker on a crotch rocketCan you show us the result, and how is it with you ?
You are gonna love it Bob, hammer down with piece of mind. Let me know how it goes. I might try to go out crusing around a little later.im going to finally wire mine up this weekend
