1 - 20 of 24 Posts
Ranger498 said:
1-can you get these items #s curt?
90401-19008 Union Bolt
90430-20016 Gasket
2-how much are black Outside door handles
3-oil drain bolt washers
4-also can you get me these items ?
hope this pic helps
#1a is the screw(i need one for each side)
#1b is the plastic rtab the screw goes into
i need one for each side (driver and passenger)
#2 i need 4 total
#3 i need the srews and the plastic tabs (total of 6 screws and 6 tabs)
#4a these are the bolts that hold the fender inplace down low i need 4 total for 2 for each side
#4b these are the spacers inbetween the bolt and the fender down low ( 2 for each side i need all 4 )
#5 i need all these tabs with the rubber hats to hold the side skirt or rocker panel (im not sure what is called )area in place forgot how many ( i need all for each side )
thanks!
thxs
Curt Aigner said:
I'll post it up tomorrow am, I'm swamped here!
np i figured as much ! :bigthumb:
90401-19008 Union Bolt List 28.01 Cost 20.71
90430-20016 Gasket List 1.43 Cost 1.06
69210-14110-c0 Rh Handle List 80.79 Cost 62.13
69220-14120-co Lh Handle List 124.26 Cost 62.13
90430-12031 Drain Plug Gasket List .98 Cost .73 Ea
90159-a0001 Screw List .49 Cost .36 Ea X 2
53145-16010 Clip List 2.44 Cost 1.81 Ea X 2
90467-09121 Clip List .95 Cost .70 Ea X 4
90179-05086 Clip List .63 Cost .47 Ea X 6
90164-40085 Screw List .57 Cost .43 Ea X 6
90105-06152 Bolt List .77 Cost .57 Ea X 4
53878-50010 Spacer List 14.83 Cost 10.97 Ea X 4
75867-14010 Clip Assy List 1.69 Cost 1.24 Ea X 14
Q41679
Discussion Starter · #10 · (Edited)
-rubber plug item in the rear of the motor, its like a tranny inspection window plug or something to that affect. since the manual calls it "hole plug "
-also how much for front and rear brake pads for a tt ?
thxs
hope this scanned pic helps
90950-01809 Plug, List 9.02 Cost 6.67
04465-14390 Pad Kit, F List 96.36 Cost 71.25
04466-14040 Pad Kit, R List 58.21 Cost 42.61
Discussion Starter · #12 ·
Discussion Starter · #14 ·
how much are both rear speaker covers ..seems mine where never returned :(
Discussion Starter · #16 · (Edited)
need
-all the bolts for rear speaker pod
-screws and covers for speaker panel and driver side rear panels
-screws for the dash plastics that hold them in place
-door plastic screw & covers (all)
-vent coupler near odb1 (under dash)that connects the center to the driver side vent.
sucks when a shop that was doing the work does not return all these items and more :(
-lower seal around driver side door
Discussion Starter · #18 ·
Curt Aigner said:
Was Your Car Stolen And Striped?
might as well have been!found all this stuff missing when i started to hear all thsi rattlke from the rear of teh car :gaysex:
i was told all the parts that seemed like they where missing where in the boxes given back to me .
all i recived back was junk from another car :(
anyways price please :)
Discussion Starter · #20 ·
Toyota emblem's
front and rear and the clips
how much thanks oh so much :)
1 - 20 of 24 Posts
